Will water be supplied from the tank to the tap when the voltage on the reverse osmosis system is disconnected?
Yuri
1155
Good afternoon. When installing a reverse osmosis filter, water fills the tank and then is supplied to the consumer through a tap. Will water be supplied from the tank to the tap when the voltage is turned off (this often happens in the country)? Recommend the brand of the filter for a summer residence, with the possibility of using it in the winter in the apartment. Thank.
    Hello. You better install a storage tank or a hydraulic accumulator, into which already purified water will flow. Since in reverse osmosis filters there are mainly tanks of 7-9 liters, this reserve is not enough to provide you with drinking water for a long time.
    If you do not want to mount the storage tank separately, you can take a reverse osmosis filter with a pump and a 12-liter tank. A pump and such a supply of water will provide you with drinking water even in the absence of electricity. For your request, for example, Atlas Filtri Oasis DP Sanic UV.
