How to choose a filter system for a yacht or boat?
Andrew
1202
Hello! Tell me which of the water filtering systems I could install on a yacht or boat.
The problem is that the water pump produces low pressure and this will naturally complicate the process of water purification. Which of the cleaning system options can I choose, with the minimum pressure at the system inlet and the smallest possible sizes. Thank.
    Hello.
    It is best to mount a filter system, which will include four filters:
    1. Coarse filter;
    2. The usual filter;
    3. Carbon-silver filter;
    4. Coarse filter for air conditioning pump.
    I am enclosing a diagram that I have sketched out by hand, so that you can better understand how the filter system will look in general. I advise you to read about the filters of the Moscow Filterroff Laboratory and see their range. I also recommend taking pumps and pipes with 1-inch connectors.
