Why is there no water in a 30 meter well?
Alexander
225
Hello! They drilled a well of 30 meters, one clay (as drillers said), cased it. He started pumping the trickle with the pump, pumped out all the water in 10 minutes, filled up in 20 minutes and pumped out again in 10 minutes, what should I do?
    Hello.
    It has already become a tradition to ask users to ask questions with detailed information on the problem. Need more information:
    1. What is your water flowing - clean or dirty?
    2. How are the neighbors doing with the water supply?
    3. What type of clay do you have there?
    4. Have geo-surveys been conducted?
    5. What equipment is installed?
    6. How many liters of water does the pump pump out?
    Your case is a 100% call of a specialist to your home, it is now problematic to diagnose the “sore” of your well in your words.
    The first thing you had to do was familiarize yourself with the features of the autonomous water supply of the neighbors. Suppose you did this, then another question is - where are your drillers? Call them boldly to your object, and make them look for the problem with their forces. If they were water well drillers, they were obliged to provide you with not only a hole in the ground, but also to visit, watch how you are doing with the water supply until you are satisfied with its quality, because you paid exactly for this. They also had to study geo and choose the ideal place for water supply with the comfort of its use.
    In addition, you have clay soil, and such wells, a priori, swing very hard. During drilling, a clay mixture forms, which is problematic to wash. The buildup sometimes lasts literally for weeks, and then you still have to wash the water for a very long time. Moreover, the filter here is unlikely to help.
    Interested in another moment with the "Brook." In general, this is a weak pump, and on their official website it even means that it will always be irrational to use it for wells, since it is vibrational and simply whips water with clay, while reducing water supply and increasing the buildup time. At the same time, on new wells, it, on the contrary, is recommended precisely for buildup. A bit contradictory information - experts recommend the installation for punching, but not for constant use, and users are noisy, there’s nothing to do with Brook and punching, 3 pumps are acne.
    My personal assumption is that you have:
    1. The well bottom is clogged.
    2.You did not fall into the aquifer.
    3. Violated the rules for the installation of aquifer equipment.
    But here it is very difficult to identify the problem without seeing its source, it is practically unrealistic. Assume the output is:
    1. Zhelonirovanie water source, that is, its washing. Many experts claim that one year of well operation is not enough for cleaning, but we had such a situation when we made the well, serious problems arose at the water supply stage and it took us about 6 hours to get it from the machine, approximately. At the same time, he was really a pro, who later on diagnosed us with a point for free from six months later.
    2. Invite other workers or force previous ones to correct their mistakes (and this, I repeat, their mistake). Leaving without making sure that you have normal water loss is unprofessional.
    This option is the best. According to on-site diagnostics, the problem will be detected quickly, you won’t have to guess. The specialist will inspect everything and say what the catch is. Maybe, of course, you will swing your well over time, but it’s better to play it safe, you have a loss of about 70 liters per minute, at best now, and this is very small. Yes, even if you just haven’t swayed yet, well, he’ll take a special 500 rubles for a consultation, it’s better than ditching the pump, wasting energy and energy in vain.
