Pressure drops in the water supply system (well + pump “Aquarius”)
Ivan
309
Greetings! For five years now, the centrifugal pump “Aquarius” (I don’t remember the model, power about 1 kW) has been in my well for quite a while, it was enough for everything, but at the time of shutdown the manometer showed 3.2-3.5 atm.
Recently, pressure has become lacking. Those. It gains the same 3.2-3.5 atm, then when the tap is opened, the pressure begins to drop very soon, a weak stream flows from the shower. At the same time, the pump in the well is buzzing, the motor is running, but the stream from the tap is barely possible. If you close the tap, pressure builds up again, but not as fast as before. With what it can be connected? Thanks for answers!
    Hello! The tightness of the piping system may be impaired, or the hydraulic resistance may increase, which is caused by clogging of the filter. If a visual check does not confirm this, then there is not enough water in the well (that is, its flow rate has decreased due to siltation). This situation is very dangerous for the pump - it may fail. If this is precisely the reason for the pressure drop, the risk of a pump breakdown is reduced by installing a pressure switch with dry run protection.
