Which pump to choose for a well in 7 rings?
164
Good afternoon! Tell me, please, which non-expensive pump to choose for a well of 7 rings, if there is only 70 cm of water in the ring. Is it possible to install a vibration pump? Or do they spoil the well?
    Hello. Your well depth is really small. Are there any sediments at the bottom: silt, sand, clay? This is also quite an important point. The fact is that even a well version of a submersible pump must have a margin of 30 cm to the bottom. And since you have a water level of only 70 cm, then taking into account the length of the pump itself, it is right back to back, a rather risky option.
    Therefore, it is better to look towards vibration pumps with a lower water intake. This design allows you to pump water at its very lowest level. Of the inexpensive options for domestic production, I can recommend considering "Kid", "Kid-M", "Kid-3", choose a model based on your needs.
    When mounting the pump in a well, be aware that it must not touch the sides (rings). I attach a visual diagram that you can navigate when installing a vibration pump.
