Which pump to install to increase the pressure of water from a well-needle?
Irina
196
Hello! In my country house, the “needle” well (Abyssinian well) is equipped. The water pressure in the house is not enough. There is a storage capacity of 200 liters with a mechanical float. Where and which pump can be installed to increase the water pressure in the house? Thank!
    Good afternoon, Irina. It is better to install after the storage tank.
    Depending on how “insufficient" you need to choose one of the options:
    1. Weaker - most likely, in your case, a normal pressure-boosting pump is suitable. The cost, depending on the manufacturer and the modification, will be from 2600 to 6000 rubles. The popular Oasis model, in the attached figure its appearance.
    2. Mini hydrophore. Comes with a hydraulic accumulator with a volume of 2 liters or more. The performance of these models is from 30-40 liters per minute. The price component is slightly higher, from 3500 rubles and higher. A major role is played by the manufacturer’s brand. Figure 2 for clarity.
    Additionally will read this article on our website.
