How to choose a pnd pipe for equipping the water supply base from the well (650m)?
Sergei
202
Hello. I'm going to lay a pipe pnd from the well to the base. Distance - 650 m. Three branches. The maximum consumer (KRS) on the farthest segment - from 1100 to 3600 m3 per month, as consumers increase. Total consumption from 1400 to 3900 m3 per month.
What diameter and thickness of the pipe do you recommend? I will be grateful for the answers!
    Hello! Unfortunately, you have provided few input data in order to indicate more accurate indicators of the diameter and thickness of the HDPE pipe for your pipeline.
    Based only on the data you provided, you can roughly assume that a pipe with a diameter of (external) 160 mm and a wall thickness of at least 14 mm will be enough. I advise you with a margin, since elevation differences are not indicated, as well as the pressure that will be maintained in the water main. PND of labor of 160 mm of external diameter and wall thickness will withstand pressure of 16 atm. and is able to provide water in the right amount.
