Is it possible to drill wells using a Bobcat-based Yamoborer?
Dmitry
Good day!
Such a question, is it possible, using the principles of hydrodrilling, to drill wells at 70-100 meters or more with a 3600 kg Bobcat base? Make rods, order swivel, etc. Has anyone tried this method?
    Hello! Hydro-drilling with a Bobcat Skid Steer Loader with Yamobou attachments is the best way to drill a well! Compared to manual drilling, this method is faster and more convenient. In comparison with other platforms for Yamobur, for example Rolls or MAZ, Bobcat is notable for maneuverability, economy and compact size. This is a great option for landscaped areas.
    Using a Yamobur, you can drill wells up to 250 meters deep, for 1 pass - 3-5 meters, depending on the characteristics of the soil. As an attachment, you can use both a Yamobur and a hydraulic drill with an auger. In the first case, you will have to additionally connect a motor pump. Renting a Bobcat loader for 1 shift will cost about 14-15 thousand rubles.
    Read more about hydro-drilling in this article.
