How to replace the BC 1.1 surface borehole pump?
Nikolay
135
Please tell me how you can replace the Kharkiv BTs1.1 surface pump for supplying water from a well 8 meters deep, in a two-story house, the storage tank in the attic. Perhaps there are more modern pumps? Please do not offer stations ...
    If you are interested in modern pumps, in particular surface pumps, then I can recommend paying attention to Belamos equipment. I believe that this will be a great replacement for your BC 1.1.
    In particular, the model Belamos XI 13, which by technical specifications will easily replace the outdated analogue. As for me, this is the best option, at a cost of $ 100 (if you take it directly from the manufacturer), you get a “workhorse”.
    Main characteristics:
    - productivity is 3,9 cubic meters. m per hour;
    - maximum height of water rise 50 m;
    - protection class IP54;
    - power consumption 1200 V.
    It is enough for your house to fill the tank with water in the attic from the well. The pump is made of metal, there is protection against overheating, high-quality components. For such a price, even the Chinese will not be able to offer anything better on centrifugal surface pumps.
