Indoor light in the Liebherr refrigerator flashes
Rashid
218
For 5 years, the interior lighting in the refrigerator worked fine. Three days ago, the indoor lamp began to blink, with a uniform rhythm (interval 3-4 seconds). I decided to replace the lamp, but replacing the lamp did not change anything and the problem remained unresolved. What could be the reason?
    Hello. It would be great if you indicated the model of the refrigerator to give more accurate advice. But let's deal with the data that is already known. So, the bulb has already been ruled out, then most likely the problem should be sought in two directions: the wiring or the bulb holder.
    Replacing the cartridge will not be a problem, this can solve your problem, if not, then a spare cartridge will appear as a bonus. You will have to dig into the wiring, if there is no experience, then it is better to call a specialist, since there is a chance of hitting something and other functions of the refrigerator may fail.
    Also, the reason may lie not in the wiring, but in the control panel, you definitely should not go there yourself, especially if the refrigerator is under warranty. As far as I know, Libherr refrigerators have a warranty period of ten years. If he has not left yet, then you can safely contact the service center for a free repair.
    • Konstantin
      Good day. You most likely need to replace one of the capacitors located on the refrigerator control board. It is located next to the compressor. In a black box with a white lid.
