Can I connect a heated floor from a heated towel rail in the apartment?
293
Hello. This question has ripened - is it possible to connect a warm floor from a heated towel rail in an apartment with autonomous heating?
    Good afternoon, Vladimir.
    You did not indicate what the heated towel rail is powered on, but a lot depends on this. Namely:
    1. From central hot water or heating. We open the housing code of the Russian Federation, part 5, art. 29 “Consequences of unauthorized reorganization and (or) unauthorized redevelopment of residential premises”. See item 3: “It is not allowed to install underfloor heating with common house water supply and heating systems (subparagraph 5, paragraph 1 of the “Restructuring Measures”) of Appendix 1 to Resolution No. 73-PP of 02/08/2005 as amended by No. 883-PP of 11/15/2005 g.)“.
    Those. it is prohibited by law, and upon detection will lead to penalties and obligations to restore the system to its original state. In practice, a large number of tenants are in violation. Will the floor itself function? Yes it will.
    2. If the washing goes along one of the circuits from the boiler, no one forbids you to equip a heated floor. A competent approach will make it easy to regulate the temperature regime.
