Missing water after installing the Aquastorozh system
Stepan
209
Greetings! Installed the Aquastorozh system. Everything worked as it should. The month was out. Upon arrival home, I discovered that there was no water. I tried to open and close several times. The sound is heard as if it works, but there is no water (although it was not turned off). Tell me, please, what could be the problem?
    Hello. It is possible that the system falsely fixes the gulf of the room, so check each sensor individually for the presence / absence of this problem. Check the control panel, what indicators are displayed on it?
    A mechanical problem is also possible in the shut-off valve: it has closed and cannot move to the “open” position. These are the three main problems:
    - incorrect operation of the sensor;
    - Control Panel;
    - stop valve.
    Good luck
