The problem with the location of the heated towel rail in the bathroom
Denis
230
Hello. There was a problem with the location of the water towel warmer. A hot water riser is located in the corner of the bathroom, and a heated towel rail is located on the opposite wall 2 meters from the DHW riser. Experts warned that at this distance he would no longer fulfill his function. How to be Thanks in advance.
    Good afternoon, Denis.
    It is difficult to answer your question without knowing the wiring. From experience, I can only assume two options (both in the figures).
    In the first option, it is possible due to expansion / contraction of pipes that water will go along a simple path bypassing the heated towel rail. The probability is 50 to 50. It depends on many factors: the pressure of the hot water supply to your house, the floor of the residence, the number of open taps. Moreover, the higher your apartment, the greater the dependence on open cranes.
    In the second connection option, it even hypothetically cannot fail to work.
