How to find out the loss in the volume of passing water after tapping?
Dmitry
183
Hello! Please tell me, what will be the loss in the volume of passing water, if you insert into the water supply system (asbestos pipe 100) with a saddle (clamp), with a half-inch exit, and then pass an inch polypropylene pipe to the water meter (meter)?
The counter will be three quarters. A half-inch pipe will go into the house. Or is it better to use all the elements for half an inch and try to look for a saddle per inch (there is a problem with this)? Thanks in advance.
    You expressed the right idea in the last sentence - to take all the elements half an inch. It is more practical and reliable. Take a saddle 1/2 inch too, why be smart with these adapters? As for the losses in the volume of passing water, I can’t tell you for sure, since there is no data on the water supply system itself, into which you will crash. But I do not think that they will be critical. Even if this is so, then you can always put a hydraulic accumulator, which will solve this problem.
