How to replace the stuffing box in the pump from the jacuzzi?
Oleg
187
Hello. In my jacuzzi, a pump flows from below, from a technological oval hole. I believe that the oil seal has deteriorated. Please tell me how to replace it at home.
    Good afternoon! Indeed, in most cases, the flow of water from the pump is associated with wear of the seals. Also among the signs of malfunction of the seals note: uncharacteristic noise during operation of the unit, a gradual decrease in power. Small power centrifugal pumps are installed in the jacuzzi.
    The seals in the centrifugal pump can be replaced independently, carefully studying the instructions and the procedure. The replacement of this type of pump seal is described in detail in this article (Breakdown # 2. Worn oil seal). A set of oil seals can be purchased for 500-1500 rubles, depending on the size, model of pump and manufacturer.
