How to connect a shower cabin to the sewer?
Tamara
145
I need a little consultation with a good plumber with experience connecting a shower to a sewer.
What height should the drain pipe be at? Is it allowed to be higher in level with the drain hole? And which option is ideal: higher, lower or at the same level?
    First of all, according to the rules of TB, you need a hood, which should be as close as possible to the shower.
    I understand that you have a cab with a pallet, so it should be above the level of sewer pipes. Accordingly, the drain pipe will and should be above the level of sewer pipes. For a good example, I am enclosing a photo of connecting a shower cabin to a sewer pipe.
    After connecting, be sure to check the system for leaks.
