What insulation to choose for pipelines of dryers?
Anna
174
Good afternoon! Please tell me which piping insulation to use for steam dryers (laundry equipment).
    Hello. For this type of equipment, I would recommend using basalt cylinders as an insulating material. No matter where the pipeline for the drying machines will be laid, this material is absolutely non-combustible. Also, basalt cylinders not only insulate hot pipes, but also avoid heat loss.
    If basalt cylinders are too expensive for you, then you can consider a couple of more affordable analogues: mineral wool and pipe insulation made of polyethylene foam. The latter is the least effective, but the most affordable.
