Where can I find the right castors for my Cersanit shower?
Dmitry
187
Good day! I ask you to convincingly help me regarding the choice of castors for a 90x90 semi-circular shower cabin with a high tray (35 cm) with lightweight plastic side panels, 175 cm high, manufactured by Cersanit. The instruction and most importantly - the rollers are lost during the repair .... I have 2 types of clips from other cabs that do not fit it, because they have a large diameter - the first is 25 mm, the second is 20 mm, see photo below.
My cabin with plastic side panels is light and judging by the slot there were smaller rollers that were inserted into a thin upper and lower slot, approximately the diameter of the slot for the roller is about 10 mm. Photo cab also enclosed.
Please tell me what to do, where to look? Thank you very much in advance.
    Judging by the photos, I realized that you need clips with fasteners on top of the door. I am attaching a photo as an example so that you can find your way around.
    As you can see from my photos, the video itself is removable there, so you can take the kit even with wheels of the wrong diameter. Then remove them and change them to rollers of suitable diameter, which can be purchased separately. Just pay attention that there is a fixed version of the rollers.
    But where to buy - to be honest, I won’t tell you. We must take these photos and go shopping, ask.
