Fans stolen from smoke exhaust and fire extinguishing systems
Victor
100
Hello, help with advice. The smoke exhaust system in the 14-storey building does not work - the fans stole! In this regard, the questions:
  • Can a building be operated?
  • Is the smoke exhaust system included in the overall fire extinguishing system?
  • How much are the fans, installation and commissioning?
  • Who is responsible for the operation of the smoke exhaust and fire extinguishing system?
14-storey 1-entrance panel residential building of the I-209 series. Built in 1969. Number of apartments: 98.
Thank!
    First of all, I want to ask: you made a statement about the theft, informed the Criminal Code. They must install new fans in the shortest possible time, since the smoke removal system is included in the general fire extinguishing system of an apartment building.
    The management system of your home is responsible for the operation of the smoke removal and fire extinguishing system, so you do not need to know any questions about prices, as tenants do not have to pay for the restoration of fans. If the Criminal Code is slowly resolving the issue, then contact the fire department directly, they will definitely help solve this problem as quickly as possible.
    From the technical documentation should focus on GOST 12.1.004-91, GOST 12.3.047-98.
