Why did the fungus appear on the walls after repair and how to get rid of it?
Vera
Hello. I really need advice!
They began repair work, plastered the ceiling with plasterboard and plastered the walls. There was no heat in the house for a month, and now the fungus has started. I want to know - is it because the walls are not treated with an antifungal agent? And the second - how to get rid of the fungus for a long time? Thank.
    Hello! Most often, the cause of the appearance of the fungus on the walls is damp. It appears in the coldest places in the house, due to the temperature difference. So that in the future he does not appear again, it is necessary that the temperature in the house is kept the same +/- 2 degrees.
    Now in stores a great variety of different remedies for fungus are sold. As a rule, they are expensive and not always effective. The simplest and most effective way to get rid of the fungus is the usual, undiluted whiteness.
    To remove the fungus you will need: whiteness, rubber gloves, a wide brush (or cloth) and a small bucket. Pour a small amount of whiteness into a container convenient for you and, dipping a brush into it, gently wipe several times on the walls on which the fungus has accumulated. After about 5 minutes, there will be no trace of him. The advantages of whiteness are that, firstly, it is very effective, and secondly, it kills bacteria that have accumulated due to fungus. Try not to allow temperature changes and excessive humidity in the room anymore, otherwise the fungus will reappear.
    P.S. when working with whiteness, be very careful. When working with her, ALWAYS wear rubber gloves! If woven, it will leave white spots. Also try not to get whiteness on the skin, it can cause irritation and allergic reactions.
