Pool circulation pump with heating
Michael
179
Hello. Tell me, please, is the circulation pump suitable from the heating system to the heated pool? Thanks in advance.
    Good afternoon, Michael.
    The circulation pump can be used to operate the pool. This is one of the main units in the system of functioning of the pool. Its type and power is selected depending on the volume and complexity of the reservoir.
    Its cardinal difference from other types is the body material (resistant to corrosion and oxidation). Since the use of antiseptics and chemicals is indispensable.
    It is unclear how the pool is heated. For these purposes, a special pump for the pool is used - thermal. After all, the use of a gas boiler or an electric heater is economically unreasonable.
    You can familiarize yourself with the intricacies of the choice of pumps for the pool in this article.
