Requirements for the APS system of a 14-story building
Jana
71
view
Good afternoon! My parents live in a 14-story building - the point of construction in 1975 in the Krasnoselsky district of St. Petersburg. The house does not work APS system.
The house has gas stoves and almost completely closed windows in the basement. Parents-engineers believe that the safety of a high-rise building is compromised. They wrote to the Criminal Code - no response. Please tell me in which current document / s you can get a description - what should be the ventilation, security system in a 14-story residential building in 1975 with gas stoves.
What organizations can I contact to conduct an inspection and draw up a conclusion on home safety? Which organizations should I contact to restore the necessary conditions for home safety? Thank.
    Hello. You need the documents included in the list of Decree No. 1521, the mandatory norms and rules that ensure compliance with the Technical Regulation on Building Safety:
    1. SNiP 31-01-2003 “Residential multi-apartment buildings”, paragraphs 4.5-4.7.
    2. SP 60.13330.2012 “SNiP 41-01-2003“ Heating, ventilation and air conditioning ”.
    3. SP 62.13330.2011 “SNiP 42-01-2012“ Gas distribution systems ”.
    As well as other documents:
    1. SNiP 21-01-97 * (SP 112.13330.2011) - about the fire safety of buildings.
    2. ПП № 870 - ТР safety of gas distribution networks.
    3. SP 402.1325800.2018 - rules for the design of gas consumption.
    4. SP 3 (4, 5, 6, 7, 10) .13130 ​​- rules that protect fire systems.
    5. SP 402.1325800.2018 - “Residential buildings. Rules for the design of gas consumption systems. "
    6. Federal Law No. 123 - “Technical Regulations on Fire Safety Requirements”.
    7. PP No. 390— “On the fire safety regime”.
    You can be guided by these documents when you write a repeated application to the Criminal Code.
    “What should be the ventilation and security system in a 14-story residential building in 1975 with gas stoves” - no. Now MKD, as a rule, do not gasify above 28 meters with rare exceptions. Yes, you do not need it, the requirements for MKD, which are given to you above, are enough. You can be guided by general provisions, they are quite enough.
    As for the Criminal Code. I suggest you write in the Criminal Code another statement addressed to the head and indicate a list of regulatory documents that you are guided by your request. You need to write in 2 copies and be sure to receive confirmation of the receipt of your application.If you have not been answered or refused, you have 2 ways:
    1. Conduct an independent examination, or contact the responsible fire safety authorities.
    2. Complain to the Housing Inspectorate, Rospotrebnadzor, the prosecutor’s office (choose where yourself) that the representatives of the Criminal Code do not want to communicate with you or violate something (attach copies of the statements and the Criminal Code response, if any).
    In principle, one does not interfere with the other, you can use both options. As a rule, in court such claims are satisfied. But, most of the rules apply only to new, reconstructed and renovated buildings. On the other hand, elementary APS can be installed at any time.
    By the way, overhaul is carried out in different bands of the Russian Federation with a frequency of 10-25 years. This is not normative, but nevertheless, you should have some approximate dates when the event is planned, especially according to the communications established in the house.
    Feel free to contact the authority, but nevertheless, write and re-submit the repeated application to the Criminal Code and arrange it as it should.
