How to calculate drainage and water supply for several objects?
Sergei
198
Good afternoon! Tell me, you need to calculate two advanced water balance:
  1. Only drainage for one 4-storey building;
  2. Sewage and water supply in a 3-storey administrative building.
From the data there are only a few figures (for example, 4.1 l / s consumption is currently going to the building for wastewater). How much will it cost and where to find the right organization?
We need approximate data for visualization, not claiming 100% accuracy (for example, the number of people is not known in the new building, etc.).
    Good day, Sergey. It is impossible to give an adequate answer to your questions with the provided initial data.
    At a minimum, understanding is required:
    1. The presence of a dining room;
    2. The number of bathrooms and their number of storeys;
    3. Remoteness from the building of the central sewerage and water supply.
    All this is carried out strictly according to the requirements of the organization of fire water supply. Even on it it is impossible to give approximate calculations. Since when calculating, in addition to the number of storeys, it is necessary to know the cubature and degree of fire resistance of the building.
    First of all, you need to contact the design organization. After receiving the design documentation, contact the construction company for estimated documentation. Having received a professional estimate, you will get an idea of ​​the full cost of both materials and work.
    Keep in mind that engineers at the design office will ask the above questions. No enterprise can prepare a project without knowing what you want. In addition, it will be useful to familiarize yourself with this article on our website.
