When to connect the gas if there was water in the pipes?
Nika
103
We have 2 storey house, 12 apartments. One day the gas was turned off because someone let water into the gas pipe. They removed the meters and put new ones on everyone, but they did not turn on the gas. How many days should they give gas? In 4 counters found water.
    Hello. I recommend that you familiarize yourself with article, which describes what to do if water gets into the gas pipe. So you at least get acquainted in more detail with the situation. Say hello to a neighbor who incorrectly connected the gas column and let water into the gas pipeline.
    Regarding the timing of the resumption of gas supply, there are no specific standards, since it all depends on how quickly the gas workers remove the water along the entire length of the pipe, where it managed to get.
