Features of mounting the integrated hood without exhaust
Irina
68
Good afternoon, I beg you help, I’ve already tortured everyone with questions, but no one can give an answer. Built-in telescopic hood with recirculation and charcoal filter, kitchen to the ceiling - I want to understand how to mount it exactly inside the cabinet, what happens there? How does air get back into the room? Through what?
Does moisture and heat remain in the closet and does the facades spoil the chipboard? Or do you need to mount the grill as a fireplace type in the facade of the upper cabinet and some kind of metal box and a pipe to be brought in from the hood or just a grill? Thanks in advance for your reply!
    Good afternoon, Irina. This site has an article “Coal hood: types, device, selection and installation rules". After carefully reading the material, you will understand that your hood does not harm the kitchen cabinet.
    Attached a screenshot showing the circulation of the cleaned air. Be sure to read the hood's data sheet to make sure that it does without air exhaust. If a challenge is required, find the conditions of its equipment in the passport. A typical text from the passport of a coal extract using air exhaust is attached - the one you need is circled in red oval.
