Where is it better to install a supply valve without heating in the bedroom?
Bogdan
143
Hello. Who knows where in the bedroom it is best to install a supply valve without heating? Under the ceiling or behind the battery?
    If you will not install additional heating on the supply ventilation valve, it is better to place it in the area of ​​the radiator. I can advise such a forced ventilation in the bedroom, where the valve is regulated and opens if necessary. The design is easy to install and almost invisible. The air supply for one room is quite sufficient.
