What equipment exists for fixing the temperature of water heating?
Novel
233
Hello! Equipment for fixing the temperature of water heating (sensor and recording device) is required. What can I pick up? Thank.
    Hello. There are special sensors with which you can record the temperature. You can read more about this in detail. here. If you need to record readings in a specific period of time, then these options are in thermostats, but not in all models. I can also recommend digital temperature sensors in which you can implement the function of recording temperature readings.
    If you need specific models, I can recommend the temperature sensor EVM-04 with a wired interface. In the attached photo, I added a table with the technical characteristics of the equipment and its appearance. It is fastened with a screw spring clip. This sensor displays the current values ​​in the heating system, and also stores hourly and daily average readings. Data is transmitted via the M-Bus.
